How many separate MPEG-1 files can be placed on a 700MB CD?
What I am thinking about is moving my home movies on to a VCD
But, when I try to use NERO to make a menu page (nothing fancy just the movies titles no thumbnails) the preview window shows only one file with no title.
And if I click any other button NERO exits
Is there a limit?
Or Is it just NERO![]()
>Get a new version of Nero
It is the new version
Just downloaded last month
Of couse the orginal question has not yet been answered.
Is there an answer
Simple Answer is 99 items be they video or still images.
But also the other limit is the size of the disk. Nero menu can be set to your desire result.
Good Luck -
Nero is hardly the best choice for a complex VCD...
A CD can contain a maximum of 99 tracks. A VCD contains exactly 1 track that contains data / filesystem / segment-items so that leaves 98 video tracks.
Thus, you can have a maximum number of 98 mpeg video tracks (sequence-items) on an S/VCD.
As for still images (i.e., segment-items), they ALL reside on track1. You can have a maximum limit of 1980 segment-items.
You will need VCDImager / VCDEasy to author a S/VCD of the degree of complexity that would make you aware of these sorts of limits in the format before something else gets in the way (like disc capacity limitations).
Regards.Michael Tam
w: Morsels of Evidence
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
