I have converted PAL VCD to mpgs. The size of the file is about 35 MB.
It stops processing the file as soon as BeSweet BeSweet finishes transcoding the file.
Looks like I have bad mpg file.
Is there any way I can validate mpg file before I invoke svcd2dvd+?
I have attached the screen capture from BeSweet window.
[img]https://www.videohelp.com/forum/images/guides/p572718/BeSweet_screenshot.jpg[\img]
Actually this window does disappear and I see svcd2dvdmpg+ as below in the log.
Here is the log from svcd2dvdmpg+:
Starting (S)VCD2DVDMPG+: v1.0.1271.35733
Begin time: 9:00:47 AM
******** Ripping SVCD images to get mpegs
############### New MPEG File ###############
File: D:\DVD\ORG\song\test\vcdcd1_02.mpg
Horizontal Res: 352
Audio SampleRate: 44100
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
******** Multipexing elementry streams
Results 1 to 21 of 21
AnonymousGuest
are you sure you got the right besweet version? 1.5b17 or 1.5b18
There is a virtualdub version (not the origional one but i clone of it) that lets you check mpgs.
Yf -
AnonymousGuest
The BeSweet version I have is "BeSweet v1.5b18 by DSPguru".
How/ where do I get the virtualdub version?
Thanks. -
AnonymousGuest
I can do that. Can you help me for the search string?
By the way you are not talking about VirtualDub by Avery Lee. Correct? -
AnonymousGuest
Thanks yf2001usa. I will search for that.
Guest,
svcd2dvdmpg+ does not have such selection. If there is one enlighten me.
Thanks anyway. -
AnonymousGuest
I can not find the virtualdubmpeg2ac3. All the link I visited pointed to one place (http://home.attbi.com/~blade66/) and that is dead.
I am really intrested in finding out why it's not working rather that having that vcd converted to dvd. -
i think you should wait till chrissy gets back.. or try to fix the besweet images cause i can't see the problem.
dang: https://www.videohelp.com/tools?toolsearch=virtualdub§ionselect=&orderby=Name , that link works fine here.
AnonymousGuest
I used VirtualDub-MPEG2-AC3 and TMPEGEnc to check the mpeg generated from the VCD and it does not seem to have any error/ issue.
AnonymousGuestWhat I mean is that those two tools think mpeg file is okay. But when I use that file with svcd2dvdmpg+ I am having issues as I have stated in the beginning.....Originally Posted by dang
WHY? -
AnonymousGuest
Try using VCDGEAR V3.0
Rip method: MPEG to MPEG
I have ripped a couple of SVCD / VCD's that will not play in Windows Media Player, after encoding them they play without sound -- Ran them back through VCDGEAR and they play & encode fine -
AnonymousGuest
I seem to be having a similar problem as you ... im trying to put the 9th gate svcd to dvd and it just stops at the same point as you've said ... i would like some help with this too if anyone knows anything
TIA
PLaCiD -
There are two reasons for the app stopping at the muxing stage.
1) you are using a version of BeSweet other than 1.5b17 or 1.5b18. ANY OTHER VERSION WILL NOT WORK!
2) your mpg is non standard.
If you are sure #1 isn't the issue, you can send me a sample of the mpeg for me to analyse. Look at my FAQ on how to do this. Make sure that the sample also exhibits this behaviour b4 you send it. Also email me to let me know you have sent something.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
AnonymousGuest
I have the right version.
My issue seems tobe the #2.
I will try to cut the mpeg file and send it to you as suggested in FAQ...after making sure that it has the same behavior...
It may take couple of days.
Is there any specfic tool that can help me to identify non-standard mpeg?
Anyway, thanks ChrissyBoy.
Playback with MPCHC while still capturing stops at old end of file
By suppa in forum Capturing and VCRReplies: 0Last Post: 30th Dec 2009, 14:11 -
When viewing an .avi file, the video stops every 5 or 10 seconds
By HartsVideo in forum Software PlayingReplies: 6Last Post: 24th Oct 2009, 07:31 -
m2v file stops to display frames during playing
By Fendervr in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 12:43 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
