Hi,
I live in the UK and currently have a NTL Digital box which I am due to cease at the end of the month. The box has only Composite outputs, and seeing as I would like to capture at the best possible quality I dont think this is sufficient to my needs.
I will be ordering Sky Digital shortly, and have contacted Sky to ask whether or not their boxes have a S-Video output to be told that standard installation boxes do not, and that were I to get SVideo I would need to sign up for Sky Plus which is £10 a month more and costs an initial outlay of £200 for a recordable box with SVideo out.
Is there anyone who can suggest a way for me to be able to capture via S-Video (as I beleive Im right in thinking this is the best source for TV capture) without having to buy into Sky Plus?
Regards
I think what's more important than the theories of S-video or composite video quality and captures is the broadcast quality.
Just like when I'm brainwashed into wanting to buy a HDTV, yet there's two channels that broadcast the signal to support it.
I could personally think of better ways to save that money rather than spend that much on the option of S-video output on the chance that your captures might produce a slightly better quality..Step back from the brink and as yourself if it's worth it man!!!!!
Unfortunately you truly won't know until you've tried it.. Isn't there any way to downgrade to the composite video without paying the penalty to give it a try?? -
marcus2704, most (if not all) Sky boxes can output RGB. Your capture device probably doesn't have an RGB input, but you can get RGB to S Video converters for a reasonable price.
This is just one example of such a device: http://www.rgbtosvideo.com/
Blackmagic Intensity Pro: Can't capture from any VCR source
By mvrx in forum Capturing and VCRReplies: 22Last Post: 31st Dec 2012, 14:42 -
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 05:03 -
Video capture & picking sound source
By nilla in forum Newbie / General discussionsReplies: 0Last Post: 22nd Oct 2009, 09:33 -
Multiple DV source Capture card/box help/advice needed please
By OdubruS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Dec 2007, 12:08 -
resolved: Need source for software for capture through ATI VIVO card
By palouse in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2007, 11:56
