hi !
I wonder whats wrong if i sometimes cant play the burned movie in my standalone dvd player(philips dvd711), but when i play it on my pc with my nec 1300 it work fine . I always use the same dvd media so i know it works on my standalone.
thanks
Results 1 to 14 of 14
Will need more information such as media and full method. You say it plays on your home pc, is this after or before you have converted it ?
Try downloading the firmware update for your player...
http://philips.ianc.net/downloads.shtml -
On my neighbours cheap dvd player it worked fine so i now try to download new firmware,ill post a result after that...
ok , it say on the firmware downlolad site that i must burn "a CD-R in Mode 2 CDROM-XA ISO9660 " .Whats that when i use nero , is it cd-extra mayby or what?????
Just found out what is was... my dvd player cant read a dvd thats under 4gb of size ...thats all
It should be able to read any DVD under 4GB. It's part of the standard. I'd try the firmware update anyway it fixes all sorts of playback problems.
that's very strange..i'm sure there are commercial DVDs that are under 4 gig.....so in this case, you wouldn't be able to play them, despite being a DVD standard....may wanna take phillips on this case...very weirdOriginally Posted by danne
Never heard of a DVD player that can't play a DVD under 4GB. I have seen commercial DVD's as low as 3.2GB so a player that won't play that DVD makes zero sense.
Its true , it cant play dvd,s under 4 gig.I just add some data outside the VIDEO_TS folder so it will become bigger than 4 gb then it works fine.I have tried it with 7-8 dvd,s know , its all the same!!!
by the way , i cant flash my dvd because its has a "prom ic" not a "flash ic" that is acciured for flashing it with a cd-r!!Thats really sucks!
what media kind? what format? -r or +r
what writing program? seems to be a lot of info not included with this OP. -
OK , i use philips dvd711 standalone, same prob with both +-r,use dvd decruptor and nero , also use dvd shrink some times ,
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 03:14 -
DVD Shrink Probs..
By Superstar24 in forum Newbie / General discussionsReplies: 33Last Post: 19th May 2008, 16:54 -
AR probs with Avi's on standalone player
By werdy666 in forum Newbie / General discussionsReplies: 7Last Post: 8th Mar 2008, 06:48 -
More dvd printing probs with r200
By parman in forum MediaReplies: 4Last Post: 28th Dec 2007, 17:14 -
tiem dealy probs with dvd player & pvr
By TILTNTURN in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2007, 11:21
