I have a couple of .avi files which I would like to create VCDs.
1. since the file is > 750MB, how can I spilt the file into 2. Is there a similar tool like TMPEGenc to spilt the avi file?
2. If I create a VCD using the avi files, will it work?
Ravi
Why would you split the AVI?
The size of the AVI has no relation to the size of the VCD mpeg size (well, at least not more than very little...)
1) Splitting an AVI file is most easily accomplished with VirtualDub.
2) How could anyone tell? Is it possible? Yes. Will you succeed? There's only one way to find out...
To help you on the way, there are plenty of guides on AVI to VCD under CONVERT left.
/Mats -
The size of the AVI file is irrelevant to the final size of the mpeg file you create for VCD. VCD compliant mpegs are approx 10MB/min so you can fit approx 80 minutes of VCD onto a 700MB/80min cdr.
If the movie length is greater than 80 min you can split it over 2 discs. Use TMPGEnc to encode your avi file to mpeg then use TMPGEnc merge and cut tools to split it in half.
Another option you have is to create non compliant mpeg files with a lower bitrate and create an XVCD that will fit on one disc, I personally prefer standard VCD though.
You need to open the avi file in vdub to check if it has VBR audio if it does you need to uncompress it to a wav file and use that as the audio source in TMPGEnc or you will find that you have audio sync problems.
See the how to convert guides for more detailed instructions on using TMPGEnc and vdub -
ok i successfully converted avi to svcd mpeg. now i want to burn it. well im new to this and i have only burnt bin/cue files in svcd format. so my question is how would i either convert the mpeg to bin/cue files, or how do i burn the mpeg so as to be able to watch it on my player.
i forgot to mention, that i have to split the mpeg to burn it, cuz it is more than 700mbs. if someone can help me with this, id be greatful.
This web site has tons of guides explaining how to do this.
Use VCDEasy to make a bin/cue from the mpeg
Click on the Guides link, this topic is covered in the guides.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
TMPGEnc to split, check the Edit section of this site.
You can burn with Nero as well as VCDEasy, check the Author section."Art is making something out of nothing and selling it." - Frank Zappa
Creating MP4 or DVD from an .avi and a .srt file using Nero 10
By criggs in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 02:04 -
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 04:12 -
Creating a header with only the data segment of a AVI file
By Hasindu in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 12:28 -
Problem creating a dvd that works on standalone players from .avi xvid file
By brycej817 in forum Authoring (DVD)Replies: 4Last Post: 17th Apr 2008, 17:50 -
Creating an .avi file form a .mp4 file
By Seagrass in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2007, 03:47
