I may be doing something really stupid, or missing an easy point, but will anybody HELP!!!
I've tried over a dozen times to create a DVD-R with 2 movies and a MENU and have, as of yet not got a working result.
I either get the black screen, which if I press play the first film plays, OR I get an empty VIDEO_TS folder.
A step by step guide would be helpful.
ANYBODY.
Cheers and thanx in advance.......
Results 1 to 28 of 28
ok well all you need to do is get your movie files togather
double click on the +vts to make another vts
drag what ever files you want to be in second part of the dvd
set your chapter langth
click menu from there you should see a simple menu
on the right type your movie names
then click make menu
and then back to svcd2dvdmpg+ and click start
and that should be it
one thing i have noticed is that once you change the name of the movie on the menu screen you want to click off of it so it saves it other wise it will come out like "movie name" movie 2 -
Thanx for the help.
Did as instructed but still got a black screen, can press up and downd to start film 1 or film 2, but dont get a menu screen to indicate name of films.. -
bubbz007Guest
I've just tried using a menu for the first time (after using the program successfully without producing a menu several times) and got the same result as smig44. It behaves as if the menu is present, but not visible (i.e. as said above, the screen is black, but you can select the two films by pressing up/down and play). The only thing i did in addition to urie's instructions was change the font size.
I am using build 1.0.1271.35733, which i believe is the most recent version.
Any ideas? -
Originally Posted by bubbz007
I had this problem with an older version of svcd2dvdmpg+..I think in the end it turned out to be a mis-placed dll or reg entry.
What OS are yo using ? I was running Win XP Pro..which fixed it... it also worked for my 2K machine...but perhaps if you're on 98/me/etc... it's still present ?
I'm sure Chrissyboy will be in touch with you once he reads this... -
I'm using win2k, I also had to copy the cyg* dll's to a different folder so the program could find them.
Without the menu's I've found the program excellent, been really pleased with it, just tried this for the first time today.
Dave H: have you tried using a menu with the most recent build ( 1.0.1271.35733) ? Is it possible a previous bug has returned? -
I'm using windows XP Pro also, and am still trying to get a successful result after MANY attempts...
I tried to burn my files with Nero and i got an error.
I figured out, that my VIDEO_TS.IFO has 0 bytes and NO VIDEO_TS.BUP files exists. Perhaps this is the problem.
If i load the VIDEO_TS.IFO with Power-DVD it sais "Unsupported File Type"
Please help me -
are you guys testing the meus on your standalones or your computer, perhaps its your dvd player im not to sure, i didnt have any problems you guys descrbed sorry i couldnt be more help
perhaps chrissyboy will be able to give more info -
Looks like I spoke too soon!
I've just converted 2 films..and have been presented with the 0k video_ts.ifo and no video_ts.bup error.
As I said earlier..this problem was resolved in an older version...CB released an update which fixed it... however... this is the first time I've tried the newest version..so it looks like the error has re-occurred.
We are testing on our pc's..however, there's no need to..as a 0k file is obviously not meant to be there...
Come back CB...we miss you! -
SVCD2DVDMPG told me, that i can get the latest Menu-Version on his hompepage, i i can´t find it.
Propably i got an onlder version.
Can anybody post the downloadlink to the latest Menu-Version?
btw. I bought SVCD2DVDMPG today!!! *gg*
I tested the Version on my SAP and it didn´t work!!! -
Cause there were questions about the menu i tried to but all i got were errors.
I've updated to the latest version and using Win XP. So i can't help you guys figure out the problem
Yf
BTW: did some of you try to creat you own menu with more then 2 vts? -
BTW, i would like to create PAL Menus.
Did anybody create some PAL Menus without any problems, or only NTSC Menus? -
My video_ts.ifo and video_ts.bup are 12kb each, video_ts.vob is 6kb. Not 0kb like a few of you have. Still just gives a black screen when tested on on standalone or pc.
what versions of menu and svcddvd2mpg are you using and what OS cause mine isn't working..
I got the latest Version of SVCD2DVDMPEG+ and the included Movie-Version!
I bought it Yesterday!!!! -
for some reason..my menu's now work ?!
I didn't change anything, or install any updates... musta just been me pc playing up on the day.... -
You should now be ok with version 1.0.1293.18567
http://www.svcd2dvdmpg.com/SVCD2DVDMPG/Software/svcd2dvdmpg+history.aspxSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
WHEY-HEY!!!!!!!!!!!!
Finally got it to work.
Cheers ChrissyBoy, many thanx for your time and effort -
LuggGuest
How about this for weird put 2 films onto dvd made a pal menu using menu 1 and worked fine.
Did another and it had no text, used all the same settings except i used diff fonts on the 2?
I shall look into it. (I got the same issue)
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
