Can someone recommend a decent capture program which will capture mpeg INTERLACED??
I have lots of programs but I've been told they capture deinterlaced.
Cheers
Fozzee
Would help if you mentioned what capture card you're using.
MMC 8.x for ATI Capture cards can capture interlaced MPEG2 on the fly. -
Originally Posted by Sulik
If you'd clicked on my profile you'd have seen my capture card
That's what the profile is there for. To save you writing your pc specs every time you post.!!
I have plenty of mpeg2 capture software. What I am looking for is one that captures interlaced.
Fozzee -
Originally Posted by Fozzee
I would suggest you try the https://www.videohelp.com/forum/search.php#search
Ps It doesn't help to talk down to people who are actually willing to help"All that we see or seem, is but a dream within a dream" E.A.Poe
http://www.cask-of-amontillado.com/htpc.html -
Originally Posted by Amontillado
I wasn't putting anyone down!!
I was simply pointing out my profile.
How was my comment any different from the posters ......
"Would help if you mentioned what capture card you're using" ??
Anyway back to the point.
You say most capture programs do it.
which ones???
I've been searching the net for answers all day none forthcoming.
I've been told PowerVCR and WinDVR capture de-interlaced so that's the main two out of the way.
Can anyone help??
Cheers
Fozzee -
I think it was the tone of the post, fozee, that Amontillado was referring. Could have been construde as a little snide.
Since you took the time to respond to the poster, wouldn't it have been better just to tell him you have an Aver TV card?
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Easycap software to capture mpeg 1/2
By visionman in forum Capturing and VCRReplies: 2Last Post: 16th Sep 2010, 10:04 -
What software will capture MPEG-1 ?
By Palmer Eldritch in forum Capturing and VCRReplies: 17Last Post: 4th Jan 2010, 18:12 -
MPEG capture software recommendations for WinTV HVR 1850
By justin81 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2009, 09:38 -
Capture Software for VHS to MPEG/AVI
By quantass in forum Capturing and VCRReplies: 1Last Post: 7th Sep 2007, 14:22
