hi,
I've converted a sound track wav (from MP3 from DIVX) to a MP2 track with the lastest Besweet. The resulting file is 4 secs shorter than the original file. Besweet reported me severals errors :
02:08:48:724] Stream error : Sync found after 1193 bytes
[02:08:48:750] Stream error : Sync found after 339 bytes
[02:08:48:802] Stream error : Sync found after 885 bytes
[02:08:48:854] Stream error : Sync found after 149 bytes
[02:08:48:880] Stream error : Sync found after 478 bytes
[02:08:48:906] Stream error : Sync found after 53 bytes
[02:08:48:932] Stream error : Sync found after 30 bytes
[02:08:48:984] Stream error : Sync found after 185 bytes
[02:08:49:036] Stream error : Sync found after 312 bytes
[03:33:48:547] Stream error : Sync found after 1394 bytes
[03:33:48:573] Stream error : Sync found after 643 bytes
[03:33:48:625] Stream error : Sync found after 362 bytes
[03:33:48:651] Stream error : Sync found after 1273 bytes
[03:33:48:703] Stream error : Sync found after 414 bytes
[03:33:48:729] Stream error : Sync found after 5317 bytes
[03:33:48:755] Stream error : Sync found after 591 bytes
[03:33:48:781] Stream error : Sync found after 850 bytes
[03:33:48:807] Stream error : Sync found after 818 bytes
[03:33:48:833] Stream error : Sync found after 438 bytes
[03:33:48:859] Stream error : Sync found after 2782 bytes
[03:33:48:911] Stream error : Sync found after 276 bytes
[03:33:48:937] Stream error : Sync found after 193 bytes
[03:33:48:963] Stream error : Sync found after 752 bytes
[03:33:49:041] Stream error : Sync found after 8891 bytes
[03:33:49:093] Stream error : Sync found after 95 bytes
[03:33:49:145] Stream error : Sync found after 121 bytes
[03:33:49:197] Stream error : Sync found after 780 bytes
[03:33:49:249] Stream error : Sync found after 155 bytes
[04:03:28:440] Conversion Completed !
Will I notice sync troubles after burning on DVD the audio and video tracks ?
Help ! what can I do ?
Results 1 to 1 of 1
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 08:26 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:52
