Can someone advice me how to do this pls? What software would I need? Preferably freeware..
Thanks in advance for your advice.
Results 1 to 9 of 9
You must have a software DVD player on your computer already, NO?
this is accomplishable in WIN DVD 4.0 and Up -push the P key during playback and a numbered bmp will appear in the capture directory
In Power dvd, just click the CAMERA ICON on the Player, then open a graphics program and PASTE..Voila..you have a bmp..
Maybe the super dvd player (freeware- has this feature..Others?) -
You can do this in vdub, open the file use the source range tab on the timeline to select your start and end points and then select, I think its called save image sequence. I dont have vdub on this PC so I cant check. Vdub will then save as an image every frame between your start and end points.
You can also do it in TMPGEnc, just set the start and end points, and then click "File" - "Output to file" - "Sequence BMP file"
Will -
if you have an ati capture card the ati file player will capture your stills hi-res. (1024xsumthin)
Well I would just pause it press the print screen button and then paste into paint, psp etc..
i tried that once and it wouldnt work! i tried it to cap a screenshot of a dvd. all would show but the screen!
As dcsos notes, you do this in your software DVD player using the appropriate controls. If your software player doesn't have this, either get another or upgrade to the newest version which does.
Not too long ago (um, three years or so?) software players did not allow you to do screen captures and, indeed, prevented it by blacking out the screen during screen dumps so you couldn't even capture your screen with the usual Windows routines. It sounds like you have an old version of software."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
I use tmpgenc. Under the noise reduction window, I scroll through the frames till I see one I want. Copy that image to clipboard, open up Paint, paste the image and save as BMP or JPG.
VirtualDub commandline - AVS to BMP/PNG/JPG
By wiseant in forum Video ConversionReplies: 0Last Post: 10th Mar 2012, 17:01 -
How to Save JPG / BMP output from *.swf files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2010, 02:32 -
Adding Bmp/Jpg to Flav
By Soixante in forum EditingReplies: 0Last Post: 11th Jan 2010, 14:54 -
DVD Flick importing jpg/bmp
By Soixante in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2009, 14:19 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 06:14
