Hi,
Any suggestion on a better tool to convert AVI movie to VCD format?
Results 1 to 10 of 10
Better than waht? I normally use TMPGEnc Plus or Video Studio 6.
Hello. -
I use VirtualDub -> TMPGEnc -> VCDEasy. In my opinion, The Three Musketeers of AVI to (S)VCD conversion.
Add to that a dash of audio editing (like WavWorks and/or Goldwave) and AVIFrate, and there's almost no AVI that can't be converted to (S)VCD.
/Mats -
Hi, what is the rought speed to convert avi to vcd and avi to svcd?!?
Eg: How long does it take to convert?!!? -
That's completely dependent on:
- Your computer specs (Which would help you and everyone else if you filled in...
What encoder you're using (MainConcept is the fastest I've used, TMPGEnc and Panasonic the slowest)
What settings you use in the encoder (motion search, CBR/VBR, # of passes...)
My system, using TMPGEnc and 2 pass VBR, high motion search precision, spends about movie length x 2.5 to encode AVI to mpeg2.
Add to that some manual work time fixing bad frames, frame rates, extracting audio, fixing sync problems...
/Mats - Your computer specs (Which would help you and everyone else if you filled in...
i'm with Mats that is the best method.
My AVI file is 750Mb and can't fit into a 700Mb CD, I tried to use
VirtualDub to split the AVI into two smaller file but unsuccessful. Has anyone tried this before? how is it done? -
Read guides. Learn. There's even a special guide on "How to fit a movie on one CD".
/Mats -
The capacity of a 700 MEGA BYTE cd is 800 MEGA BYTES of VCD fare
NO THIS IS NOT A MISPRINT
You can put 800 megabytes (well 799 really) on a 700MEGABYTE CD-R if you use the VCD format
This info used to be in the VCD guide but is now MISSING -
...and even more important - the size of the AVI has no relation to the size of the mpeg produced when creating a (S)VCD. Only things that govern the size of the mpeg is length (in time) and bit rate used when encoding. Size of source material has nothing to do with it.
/Mats
(on vacation!)
Convert AVI to Mjpeg-II or other format
By hemang in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 07:23 -
Help convert avi to WD HD Player -Playable format
By anbures in forum Video ConversionReplies: 1Last Post: 7th Nov 2009, 05:27 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 00:00 -
what format to re-convert avi into?
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2008, 01:23 -
Convert AVI from digital camera to what format
By hemang in forum Video ConversionReplies: 14Last Post: 24th May 2008, 07:13
