I just loaded it up and went to import my vobs, and it gave me a too high bitrate error. I dont see how it happened, the vobs came from an actual DVD disk, then ran through DVD2One
now when I made my THX and Dolby digital trailer demo DVD it gave me the same warning I went ahead and authored them and so far the DVD plays on any DVD player, it said something about the video had to be no more than 9000 so with audio it would be less than 9800 mine was something like 9864, but like I said so far plays fine.
This is a common problem. Select ingnore or if your authoring proggy don't allow you this, get DVD Patcher and patch the headers of you source file.
I have this problem all the time from DVB transmissions. Many DVB Channels state "15000kb/s, while they are 4000kb/s at best!
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 14:37
