Hello,
I have from a friend the Pearl Harbor VCDs, and with the freindly fact, that it is saved in *.dat.
So my qustion is, where and HOW can I produce such files,
as first of all, the *.dat file is smaller than mpg and I think it is a better quality.
So, where can I make from my *2dv (from DVD2AVI) or dirctly from mpg files such *.dat files??
And, only for interesting, for what stands DAT??
Thanks, Math
VCD *.dat and .mpg is almost the same. Burn a .mpg as VCD and you will end with a .dat.
The dvd2avi project (d2v) is a reference file to encode the .vob to .mpg or whatever.
http://www.vcdhelp.com/dvdripping.htm
http://www.vcdhelp.com/convert.htm
http://www.vcdhelp.com/burnmpg.htm -
you can convert .dat to .mpg with vcd cutter
You know what ? juat copy the .dat file to your harddisk and rename it to .mpg and VOILA,you're back in business. Amazingly you can burn the renamed file to vcd.I've tried it with Nero anyway -
The DAT file is not quite the same as a VCD compliant MPEG file. You should always convert it back to standard MPEG (i.e., with VCDGEAR) before doing anything with it.
Nero can directly use a "DAT" file to burn a VCD -- thus renaming it to ".mpg" is irrelevant. However, it is unclear how many other proggies will handle a DAT file masquerading as an MPEG.
You can also convert a .mpg --> .dat (with VCDGear), but there is absolutely no point of doing this. When you author a VCD and burn it, the source mpeg file will automatically have the extension of .dat on the actual burnt disc.
Regards.
Michael Tam
w: Morsels of Evidence
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 08:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 21:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
