Is there anyway to get VCD's in better quality?!?!? Please Help!! Thank you, much appreciated!
In need of better resolution...the source is Kazaa and TMD.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator pacmania_2001
Closed Thread
I would recommend buying them from a place like www.eurekamovies.com or buying the DVD from a place like www.amazon.com.
They far exceed (in terms of quality) Kazaa's pirated (and re-encoded) AVI files that you are seeking to download.
Also, as I have warned you (informally) about this in the past and yet you continue to do so I am locking this topic and issueing a formal warning.
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
