Is TmpGEnc Plus 2.5 is the only way to convert Mpeg2 to AVI or DIVX?,with good quality....or is ther a freeware out there?
Results 1 to 14 of 14
I suppose you could use the MPEG2 version of virtualdub and save as avi...Originally Posted by tonyrome_1
TMPGEnc will not encode to anything other than mpg1 or mpg2.
Look for Virtualdub mpeg2 ac3 in the tools section. It convert mpeg2 to avi. -
No one ever mentions my favorite PROGRAM
for this little task anymore
DIVX or AVI from
VOB* (DVD) or MPEG-2
and vidomi is so simple to use
wwww.vidomi.com
FREEWARE..GO!
*vob's gotta be on yer hard drive -
Its only $48. Unless you are not looking directly from Pagasys Inc. Maybe you found a retail box version elsewhere?Originally Posted by tonyrome_1
BTW, I just went to the web page and see they no longer sell the retail box version and give us a reason to check your spell checker...
err... having trouble comprehending... the closure... of the web page....The TMPGEnc Plus 2.5 retail box version purchase website is currently closed. Thank you in advance for your comprehension.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
mgh, look in TMPGEnc Plus at the file menu in the output to file section. It lets you save as mpg or avi.
Howard -
Vidomi isn't even on the tools section I think!
dcsos, report this tool in the list, it is a very good one for this task indeed. -
Thanks Baldrick
If .469 doesn't run on your system, version .346 is bullet proof
I use VIDOMI constantly to make VCDS in a two step process.
It makes a DIVX AVI that I've no intenion of saving..
sort of a digital internegative..
This AVI can be placed on the TIMELINE in VEGAS or PRIEMERE and quickly output as a VCD
(all this beause neither accept MPEG-2 on the timeline directly especially with ac3 attached..)
The trick is the digital internegative 's audio must be a conversion of the ac3 from the DVD to PCM
not the usual MP3 audio that DIVX's have.
this makes the internegative stuttery in playback even on a 1 gig machine..so I discard it after making the VCD
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
I juts check out the price of TmpGEnc Plus 2.5...$125
