How do I turn .dat files into mpeg files I can watch?
Is it not possible to get a burner to run at 1x or 2x for burning speed?
Thanks.
If everything is infinite then nothing is definite.
To convert from .dat to .mpeg
http://www.vcdgear.com/download.html
I think it would be the software that would determine the burning speed.[/quote]"Today is only yesterdays tomorrow" -
The longwinded way would be to use a program, the easier way would be to use ISOBuster to extract the dat file from the disk, but those the filter MP2 frames option.
Another way of doing this would be to just rename the .dat to .mpg and you have a playable file. Ie: if you are using windoze then goto windoze explorer, highlight the file, right click, select rename delete the .dat and replace with .mpg
You can let the software you are using determine the speed if you like, or purchase an old burner or you could purchase some low speed disks ie: x1 x4 speed. Then use them to burn your files onto. The question of course would be why would you want to?
HTH
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 08:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 21:27 -
Retrieving image DAT files from a photo slide show
By cruisebloke in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 10:15 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
