I have panasonic dv-f727 dvd player, which will not play normal svcd's, but will play vcd's, on a rear projection tv. I have been trying to make svcd's using the tmpgenc header trick. I tried using different settings in tmpg multiplex, simple multiplex,and svcd easy vcd1.0 complient and vcd 2.0 complient vdc. I am using nero to burn the svcds as a vcd. When I play the (S)vcds on my computert they are fine and full screen. When I put them in the dv-f727 the video shows up only on 2/3 of the screen side to side and 100% vertically. I have tried ther download able test svcd ntsc image with all variations, but it has not helped. In the DVD player section several users that the dv-727 will not play svcd's, 1 says it will. In other searches the information is also conflicting. any suggestions are appreciated.
Thanks in advance,
Michael
Results 1 to 1 of 1
Laptop is showing nothing on screen.
By chewie8008 in forum ComputerReplies: 4Last Post: 26th Jun 2011, 22:56 -
Problem with the monitor: showing only white screen
By 1234567 in forum ComputerReplies: 0Last Post: 8th Aug 2010, 12:26 -
Windows Media Encoder Showing Green Screen Any Help?
By simpleatif in forum Capturing and VCRReplies: 1Last Post: 21st Jan 2010, 18:19 -
ffmpegX splash screen still showing after registration
By Le Main Event in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2009, 10:11
