Done this for years running W98 no problems.
Running XP pro. Installed ASPI layer etc. To keep Smartripper (2.41) happy.
Problem is this:
Rip VOB to HDD with Smart ripper.
Then run DVD2AVI (1.82) to Get seperate Audio/video file.
Go to load the .D2V file for TMPGE (254)and cannot select it(or even see it), I choose View/ all files then select the file but recieve the error message " Cannot open or unsupported file"
Has anyone encounted and found a fix for this problom.
Cheers Dudes
Welcome my son, welcome to the machine.
Hello, Yes I too have the same problem. I have used the same procedure for quite awhile and all of a sudden my TMPEG wont recognize the d2v extension either. Im not sure if the problem lies in TMPEG or DVD2AVI. Im working on it and as soon as I figure it out Ill let you know--Sorry
radman, likewise I'll do the same and let you know when i get some joy, Im trying to fing my older versions of each just out of curiositys sake, as I know they also once worked. Also just about to install and try the same on my second machine running 98, so we will c what happens.
Welcome my son, welcome to the machine. -
Ive cracked it, downloaded DVDdecrypter and latest TMPGE, ripped vobs with decrypter, ran through original DVD2AVI (182) and was able to load it with new TMPGE, then checked with TMPGE (254) and was also able to load it, so problem layed with Smartripper for some reason.
Try this and good luck.
Cheers
DaveWelcome my son, welcome to the machine. -
I have been reading and found out that you can also go into the options setting, then environmental setting, then VFAPI plug-in, right click on direct show multimedia file reader and change the priority to 1 or 2 and then try to open if not then try priority 4. I havent tried it yet as Im at work and cant get to my comp ARGHHH. I will try your solution first Thanks
you wouldn't happen to have 2 versions of dvd2avi installed, would you??
for some reason, if you made a .d2v file from version A and then opened up version B, tmpgenc will say that the .d2v file from version A has "file format unsupported". all you need to do is open up version A and then close it. tmpgenc will then recognize version A's .d2v file. -
Hello, I figured it out I had cladxp, it expired so I deleted it. unfortunately my dvd2avi files were in that cladxp folder, so a file was missing that TMPEG needed. I reinstalled cladxp and everything works great.
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 14:23 -
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 10:10 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 21:29 -
Wierd, can't demux TS file, plays in PowerDVD but not VideoLan or wm
By gbimmer in forum Video ConversionReplies: 0Last Post: 29th Dec 2007, 14:51 -
Help! Wierd problem of Sharp Aquos 46D64U
By cryogenics in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2007, 22:56
