  1. Hi,
    My Sony DAVS800 DVD player states it is locked when trying to open the DVD tray.
    I would be most grateful if anyone can tell me how to solve this problem as otherwise I'll have to send it back and it will take about 6 weeks for Curry's to get round to doing it!
    Many thanks
    DAZ
  2. most larger Currys stores have a technician onhand.
    just ask for the repairs dept,take it in,and the chances are that they will fix/remove whatevers causing the problem.
    i took my 28"matsui tv thats was in my bedroom,saying it was my grandads and he couldnt be without it,all he had n all,blah,blah...
    and the guy resoldered the points on the board that were "dry".
    it was still under warranty ,so , no charge.
    Jan 2002
    When my player locks up I unplug it and it seems to reset so I can open it.
  4. is it something to do with the parental lock.
    i know that my parents old panasonic dvd player wouldnt let you open the tray unless you entered a code."full parental control" it was called.
    dont think it is,but its strange that it says "locked".and thats what mine does when i set the lock to "on".
  5. Hi, I have tried disconnecting it. It says all clear then when u try to eject reads locked.
    Also tried parental control which was switched to off!!
    Any other ideas please guys?
    CHeers
    Daz
