I have a PAL format video with a resolution of 480x576 (16:9). I want it to be in a 4:3 mode because I don't have a widescreen tv. I'm using Machine15's guide to convert the pal to ntsc format. What settings do I use to get the movie to look right on my tv screen? I did it with the defaults but I did choose, full screen keep aspect ratio. On the TV, where the credits are rolling at the start of the movie, the names get cut off a little bit on the sides and sometimes a little on the bottom. What are the exact settings I need to use here? Any help would be appreciated, thank you.
Also, when I use AVICodec to determine the specs of the pal video it says 480x576 (16:9), and the converted file I have in NTSC says 480x480 (16:9). I thought 16:9 was widescreen, but it appears as full screen on my tv. I would settle for a widescreen format with the black bars, if it would look better and not cut off the edges so I can see the full words/actors, etc.
16x9 is widescreen (well one of them). SVCD doesn't support Anamorphic Widescreen (if I'm not mistaken). You need to set TMPGEnc to 4:3, then choose Full Screen, Keep Aspect Ratio. That will center the image, and give you a widescreen, letterboxed image.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
What you suggested didn't work out, it still puts it in full screen. The only way I can make it go with the black bars is if I choose 4:3 for the video and under the advanced tab I choose 16:9 display. Then it puts the bars, but it still looks like it cuts a little of the letters off. Since I am using the NTSC copy that I already made to try to convert it with the black bars, maybe that is the problem. When I encoded it could've been cut off then because I was just doing 4:3 I'll have to try the pal version again and see if that works
Thanks -
Yeah, that's what I meant. I'm sorry I guess I didn't make myself clear. I meant on the video tab use 4:3, and the Advanced tab use 16x9, then choose full screen, keep aspect ratio. Sorry
Zefram Cochrane
2073
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 03:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 08:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 03:57 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 01:41 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 18:59
