Hi guys
I captured a documentation with my capture card and windvr and got a mpeg-2 file with a size of 950 MB.
I don't want to use two cd's to burn this file, so I'm looking for a way to re-encode the mpeg-2 file, probably lowering the bitrate in order to make the file fit on 1 cd.
Is there a tool that can do this?
thx for any help
Go over to the tools section and download DVDPatcher. You MIGHT be able to lower your bitrate using this.
Good luck!Just what is this reality thing anyway? -
DVDPatcher will NOT lower the actual bitrate and reduce the file size as is required. The only option is to re-encode. To do this you can use TmpGenc (hass certain issues opening mpeg-2 as source files though), Cinema Craft encoder (Won't open mpeg-2 files directly, need to frameserve) or Main Concept encoder (which I think Will open mpeg-2 files).Originally Posted by i_am_dave
Hope this helps. -
I am succesfully using Mainconcept to re-encode MPEG-2 files. You can use the SVCD profile which selects all the appropriate settings for you.
The more I learn, the more I come to realize how little it is I know. -
Yes, the TMPGEnc wizard can do it, or you can manually do it with a bitrate calculator. What is the present resolution and bitrate?
Hello.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
WinRAR MPEG(video file) Compression Gone Haywire
By hech54 in forum ComputerReplies: 4Last Post: 20th Mar 2012, 15:13 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
WMV vs. MPEG compression artifacts?
By smexxy in forum Video ConversionReplies: 5Last Post: 17th May 2009, 00:33 -
I am at my witts end trying to reverse MPEG-4 compression. Help!!!
By forensic in forum Video ConversionReplies: 9Last Post: 30th Apr 2008, 13:16
