Hi folks!
I just finished building a DivX-movie with two integrated AC3-streams (eng./ger.) which can be selected through the player's menu (Zoomplayer). It works really fine. But as the file is about 1.2 GB I wanted to split it for burning on two CD's. Unfortunately, after splitting the file the parts do not contain the second stream anymore. Also the sum of both splitted parts is smaller than the original file (the difference is the size of the second stream). Does anyone know how to split such a file by keeping both streams working in both parts?
Would be very glad to get some hints.
Thanks!
Sensenei
Results 1 to 1 of 1
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
Cutting and Pasting Hi Def Transfer Streams in Native Resolution
By Jcage89 in forum EditingReplies: 6Last Post: 21st Aug 2008, 12:17 -
Cutting/Stream-copying AVC1/AC3 inside MKV
By honeyko in forum EditingReplies: 0Last Post: 1st Nov 2007, 21:14 -
Alternative AC3 cutting and joining tools
By 557953 in forum AudioReplies: 2Last Post: 21st Aug 2007, 11:11
