Hello,
I'm confused.
Many on this forum have suggested using something like Toolame or ssrc.exe to encode to MP2 audio, for TMPGEnc's conversion formula for audio is not the best.
I've read on how to use the external tools inside of TMPGEnc in order to access these programs. My question is:
When you convert AVI to MPEG 2 using TMPGEnc, I'm familiar with loading the source AVI video file and an audio file I've since converted to WAV to let TMPGEnc start converting. If you're using an alternate program to encode the audio, how do you do it? Do you simply load only a video file for the MPEG 2 conversion, then convert the audio separately using the other program, then re-combine them? Or is there a way to tell TMPGEnc to use itself to code the video and another program to encode the audio?
Thanks,
Brian
Originally Posted by metranil
(Ver. 2.58 and previous versions) Options, Environmental Setting, External Tool
(Ver. 2.59 and later versions) Options, Environmental Setting, Audio Engine
Any-Audio-Converter splitt time help
By Blå_Mocka in forum AudioReplies: 2Last Post: 31st May 2011, 06:52 -
editing with alternate scenes and audio
By }{eywood in forum Authoring (DVD)Replies: 18Last Post: 17th Feb 2011, 02:23 -
Popcorn Audio Converter Problem
By duracell in forum Newbie / General discussionsReplies: 2Last Post: 8th May 2010, 03:57 -
OGM to iPod with alternate audio track
By Salva Veritate in forum Video ConversionReplies: 11Last Post: 13th Feb 2009, 17:09 -
VRO to MP4 - please suggest a faster converter than TMPGEnc Xpress 4.0
By mbextreme in forum Video ConversionReplies: 2Last Post: 26th Aug 2008, 17:24
