When converting an avi(101 min, 06 sec.) movie to an MPEG2(DVD-R) using TMPGEen, I get an overrun error on the last screen. It informs me in the "movie info" that the time of the avi is 302 min. 14 sec.
This continues to happen even when I clear the program or re-start it. It also occurs with other avi's, but it gives me different times.
Any ideas???
Your avi probaly has VBR encoded audio, which TmpGenc doesn't like. Use virtualdub to extract the audio to an uncompressed wav file and use that as the audio source when you encode.
When I do that, the audio sound like it's behind a fan about 15 minutes into the movie. Why is that?
Are you doing it this way?
https://www.videohelp.com/virtualdubaudio.htm"Today is only yesterdays tomorrow" -
Hi, I have had the same problem and the latest version of virtual dub will change from vbr audio into something that tmpenc can use. Instead of extracting the audio, I just frameserv into tmpenc and it works like a charm.
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
