hi.
when i rip some movies (i.e. lotr extended edition) and then open the directory with dvd2one, it detects 2 movies of identical length.
how do i know what's the difference between them and choose the right one?
i've tried to process both and open the results in powerdvd, but they seem identical.
thanks, jeremy.
What I've done is to go to you DVD player and pick the widescreen movie at the menu.(assuming that is what you want to backup).
Once it starts playing, not the title etc on the player. Widescreen has always been for me the first one.
I usually use Shrink which tells you the title number. I would assume that DVD2one would list them in order. -
thanks foolishbrett, i supposed first one was the one to choose but wasn't sure.
cheers, jeremy. -
This is not just an issue of widescreen and fullscreen on the same disc. In fact, in the case of the LOTR it is most likely a case of one having the normal dialog audio tracks and the other having commentary audio tracks. Ony any DVD which has ONLY widescreen or fullscreen and not both, this is usually the case. I believe this is the case because the DVD standard only allows up to 2 audio tracks to be assigned to each video. So, if there are more than this, they must create another duplicate video track.
I always open one of the .vob's directly in my dvd player to see if it's the set I want.
BD to MKV fix lenght
By cormiodo in forum Blu-ray RippingReplies: 7Last Post: 27th Nov 2009, 04:33 -
write 2 movies in 1 disc
By akakiami in forum DVD RippingReplies: 6Last Post: 10th Sep 2008, 07:06 -
HELP: How to Choose/Pull One Feature from a Disc with Two or More
By dogra in forum MacReplies: 5Last Post: 11th May 2008, 21:23 -
Two movies on a 4.7MB disc??
By Noy2014 in forum Authoring (DVD)Replies: 5Last Post: 15th Aug 2007, 11:08 -
Why won't identical hard drive work in another identical PC?
By rijir2001 in forum ComputerReplies: 8Last Post: 25th Jun 2007, 09:12
