thnx for the essay dude but i am confident if i change my discs my dvds will work
Results 31 to 36 of 36
No burned discs will play on all DVD players, some players are simply not capable of playing burned discs, or are only capable of playing - or +. As cornacopia has said "DVD-ROM" are pressed not burned.
but like i have said my friends BURNED dvd works on my dvd player and ps2. where as myne doesnt and they have both been done the same apart from there different disks. So..........Im assuming its the disk i am using
Try using one of his discs on your system and see if that works.
Couple of points of order (as it were) + suggestions:
1) The AUDIO_TS folder is not required for DVD-Video, its actually part of the DVD-Audio spec but will be ignored by a DVD Video player, as will anything else in other directories;
2) Cornucopia is pretty much correct, although I'm sure the Book Type settings can be overridden (some DVD+R writers can be changed to do this even for DVD+R discs - it must be in the image somewhere);
3) Have a look a www.disctronics.co.uk website, they have lots of interesting info on DVD formats. From what I can gather, DVD Video should be UDF Bridge format (UDF + ISO), 8.3 filename structure, no Joilet, etc;
4) Try and get a look at the official book specs (easier said than done), by the sound of it the book type is used in each sector (I think) so it should be easy(ish) to change it.
Good luck and let us know how you get on, when I've got time (and a burner) I'll try and digest the info from disctronics and put a definitive guide for burn spec together to achieve maximum compatibility (ignoring the easy one of having the same brand DVD player as DVD burner - and even thats probably not guaranteed to be 100%!).
J
5) Try the media your friend uses. -
ok thnx for replying all you who did and i hope it works and its much appreciated. I will go try ur ideas and will let u know how it goes
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Hybrid disc with both DVD-Video & DVD-ROM - is it possible to burn?
By rjamesd05 in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2009, 13:07 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
