My friend wanted me to make a copy of his harrypotter dvd for him. I split mine on 2 dvds. When I use tmpgenc dvd author I get no audio on 2nd dvd. When I play it, there is audio, but can't find audio file on any of the vobs. And vobrator only finds .spes file for audio. Don't remember what program I used to split the dvd. And dvdtoolbox after processing there is no audio anymore. So where does the dvd player and power dvd get the audio, when I can't find it?
Results 1 to 9 of 9
Try using some other tools like Smart ripper, dvd2one and copy2dvd I get great results every time.
Originally Posted by scottvf
If you want to discuss how to make personal backups for your own use/safekeeping then that is fine. -
Ulrich, I guess you didn't understand what I was trying to say. The dvd copy that I ripped is on 2 dvds. The 1st one is ok, but the 2nd one showed no audio files in the vobs even though it has audio when you play it. So where does the audio come from. This is only on the 2nd dvd which is a split copy of the original. The original is damaged so I can't use that. What I'm trying to do is put 2 dvd's together as one. I did it fine with lord of the rings.
Try using some other tools like Smart ripper, dvd2one and copy2dvd I get great results every time.Ulrich, I guess you didn't understand what I was trying to say.
BTW, wish I could help, but I haven't a clue. I've merged DVDXCopy discs, but with VobEdit.
LTA -
Originally Posted by Triple_Helix
scottvf, from what you have already said, you should have the original, so why not start from there? -
Maybe, but your response is no better, at least ulrich suggested something!
LTA
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 02:01 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Dummy audio file in silent DVD?
By elkfir in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2007, 23:24 -
I cant watch my dvd file videos without audio...
By mmmipa in forum Newbie / General discussionsReplies: 7Last Post: 10th Sep 2007, 02:22
