I have a DVD that I’m trying to make a backup of and one of the VOB files is messed up. I use ISOBuster to extract the files and one vob will give me about 16 errors. I figured this will give me a few “glitches” in the move but I’m not worried about that. The problem is DVD Shrink will not read the files.
Is there a way to recreate the IFO files for the “new” vob file? I’ve looked at Ifoedit but didn’t know what to do with it in this situation.
Does this disc have something actually wrong with it? If so what I'm gonna suggest may not be much help. But if its just an error that seems to pop up only on this disc you might want to try ripping from another DVD drive if you have another, it sometimes will not rip some dvds with some drive, usually trying another drive (such as switching from your DVD-ROM to your Burner) helps.
As far as recreating the ifos, not sure if its possible or not. Maybe someone else knows.
How to Convert VOB file from DVD with ignore read errors
By designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:17 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Errors in .VOB file burning as Data CD
By misterbean in forum Newbie / General discussionsReplies: 0Last Post: 8th Apr 2008, 01:31 -
STRANGEST problem getting VOB errors on DVD Decrypter, IsoBuster, etc.
By Corellian Corvette in forum DVD RippingReplies: 7Last Post: 16th Feb 2008, 19:52 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
