I trying to capture some home movies onto my PC from my 8mm camcorder. I have an ATI all in wonder graphic card to do the capturing. My question is what is the best sofware to use for the capturing. I have the software which came with the card (will alow me to capture at 4 settings from VCD to DVD quality) & Pinnacle Studio 8.1 which came with the card. I also have a copy of Ulead DVD movie factory which will alllow me to capture or should I dump the lot and use Virtual Dub & Frameserve to TMPGenc? Or should I download/purchase some other software?
Thanks in advance for any comments or suggestions.
Results 1 to 9 of 9
Vdub and TMPGEnc gets my vote. It's what I use and have found no reason to change my mind.
my capture card doesn't play nice with Virtualdub, so after some testing I found that iuVCR gives me good results - kludgy interface, but highly customizable, great audio sync and few dropped frames (<8 / hour )
from there, encode with TMPGenc, author with DVD Lab.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
IUVcr. 30 day free trial, give it a shot and compare.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Pinnacle Studio 8.1 does not come with ATI card's ATI has there own software. just use ATI software use MMC 8.1 or MMC 8.5 and but on the filter in setting when you make your own template's use heavy news or sport's to clean up old vhs tapes
For an ATI card I would recommend the MMC 7.x series and the Ulead Videostudio.
I used to use VirtualDub, but I had some issue with it. For some reason it did not want to play well with my cap card all the time. I liek virtual dub and use it for editing now, but Ulead does better for me in not dropping frames. -
I use the version of Virtual Dub that keeps audio in sync without dropping frames. http://www-user.rhrk.uni-kl.de/~dittrich/sync/
Then I use TMPGEnc Plus to convert to DVD mpg2.
I am very satisfied with the results.
Howard -
VDub, iuVCR and AVI_IO are the most popular choices. VDub is freeware the other two are shareware.
Capture Software Recommendations?
By Prince Valiant in forum Capturing and VCRReplies: 19Last Post: 18th Jun 2011, 00:59 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Software for Capture
By ashkan_vpm2 in forum Capturing and VCRReplies: 1Last Post: 6th Feb 2009, 15:03 -
Need Capture software ?
By cccf25 in forum Video Streaming DownloadingReplies: 1Last Post: 24th Jun 2008, 19:59
