  1. Okay so I want to rip a dvd, i know how to do that but then i want to convert it to vcd what is the best prog to use, i have tmpgenc and virtual dub will these do it?
    TIA.
  2. TMPGEnc for converting to mpeg1, then something like Nero or VCDeasy for authoring and burning.
    See the how to guides on the left
  3. Thanks mate for the reply, but I'm now using movie Jack which basically does it all.
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Yes they will so throw away your MOVIE, Jack
  5. Can you clarify on your reply please. You saying movie jack is no good or I had the right idea?
  6. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Sorry, I was being silly...
    YES YOU HAD tHE RIGHT IDEA..
    but if movie jack works with one click who am i to argue?
