  1. Guest
    My program hangs durring the Multiplexing elementry streams. When using a bin it creates the mpg file, but not the VTS. Just got the new version of SVCD2DVDMPG+, but still no luck. I am also using BeSweet v1.5b18. Wondering if anyone could help? I also have read many of the other forums, but still no help. Thanks
  2. Guest
    Here is Everthing in my program SVCD2DVDMPG+
    Here is my BeSweet folder v1.5b18
    Here are the settings in the program for the movie ctp_ident1.bin (identity)
    Wondering what I am doing wrong? Thanks again.[/img]
  3. could you do something about the images? I can't see them.
    Do you have the same problem when running mpg files?
  4. Guest
    Yes I have the same problem with running mpg files. I will try to update the pics soon. If I close the black box once it stops durring multiplexing, it begins a new MPEG file with my cd2 of identity and does the whole thing over again and then i have to close it again when it stops durring multiplexing and then it says creating dvd, but it will only do the first few minutes of the movie and then it says complete?
    This is what it does...
    Starting (S)VCD2DVDMPG+: v1.0.1271.35733
    Begin time: 5:14:11 PM
    ******** Ripping SVCD images to get mpegs
    ############### New MPEG File ###############
    File: H:\Identity2\ctp_ident1_01.mpg
    Horizontal Res: 480
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    ******** Resampling audio from 44.1 KHz to 48 KHz
    ******** Multipexing elementry streams
    --- Conversion details:
    File: H:\Identity2\ctp_ident1_01_DVD.mpg
    Horizontal Res: 480
    Audio SampleRate: 48000
    File: H:\Identity2\ctp_ident2_01.mpg
    Horizontal Res: 480
    File: H:\Identity2\ctp_ident2_01_DVD.mpg
    Horizontal Res: 480
    ******** Creating DVD...
    Creating VTS #1
    ============ Complete ============
    ============ Duration: 00:45:39.6875000
  5. i know a few things.
    1. big (more then 2 gigs) mpg will not work.
    2. mulptiplexing takes a lot of time. (8 vcd eps on my p4 2.4 takes about 2,5 hours)
    yf
  6. trinity12345
    Guest
    so when it says multiplexing elementary streams is it actually doing something as no blck box comes up and i leave it and nothing seems to happen any ideas
    t
  7. i don't know i never looked at it just let it run when i sleep..
