When I output (a .dat or .mpg file) from my computer to TV using WINDVD, the screen size adjusts to fit on my television (which is ok). But the audio is out of sync. If I play the the file using WMP then it does NOT automatically adjust to fit my television, but the audio is in sync.
Is this expected? and can I correct this in anyway?
Obviously I can manually change the window size of WMP, but this certainly isn't a convenient solution.
Have you had the chance to test the DAT,(s)vcd file on a friend's DVD player to see if the sound sync issue is the same there?
No, I haven't. That is actually part of my problem. I don't have a real DVD-player. I have PS2, x-box, and my computer. My dad has a DVD-player though which might work. It is a paradox for me because if I can't get these VCD's to work then I will buy a DVD-player, but I can't tell if they work until I have one to try them on.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 23:43 -
WMedPlayer WinDVD & VLC will not play video - only audio. Not codec rel
By ligedy in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2007, 03:57
