Results 1 to 10 of 10
  1. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    Does anybody know what kind of chip/processor XBOX and PS2 use? Or do they use one at all? Just curious...
    Apr 2003
    australia
    I seem to remembr reading somewhere that the PS2 uses an intel P3 processor, while the new playstation thats coming out will use a P4
  3. Member pyrate83's Avatar
    Really??? Huh, well that's interesting. Thanks. 8)
  4. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    XBox uses a modified PIII 733.
    The PS2 uses custom made chips, one is dubbed the emotion engine.
    If you go to either official web page, the specs are listed there.
  5. Member pyrate83's Avatar
    Thanks disturbed1...I was just at those sites. I'm impressed to know that my XBOX outperforms the PS2 though. In graphics processing and in CPU speed.
  6. Originally Posted by pyrate83
    Well, you have to remember that the PS2 is the oldest "nex-gen" console of them all. I think the PS2 may be a good year older giving it a distinct disadvantage.
    Maybe they will up its power in the PSX, but I doubt it. Sony will probably wait til the PS3. After all, the PSX is just a multi-purpose PS2.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  7. From memory both XBOX and PS2 use the Intel Pentium III as the main CPU.
    The "Emotion Engine" of the PS2 refers to the graphics card / GPU.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  8. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    PS2 uses a Risc processor, just like the PS1 did. So it can maintain backwards compatibility. So that rules out a PIII
  9. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Here is some good info on the PS2 hardware.
    http://www.arstechnica.com/reviews/1q00/playstation2/ee-1.html
    http://www.arstechnica.com/cpu/2q00/ps2/ps2vspc-1.html
    Not its stats as much of a tech breakdown of how it does those things it does.
  10. Originally Posted by flaystus
    Seems like you're right... I wonder why I thought differently...
    Regards.
    Michael Tam
