When I capture In Scenealyzer Live, every few seconds or so a box pops up real quick saying to please register.
This is real annoying when I capture making my movies useless.
Is there a way to get rid of this?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator flaystus
Results 1 to 12 of 12
Since its a 30 day trial, I can;t get help or something?
I don't understand why that warning was necessary
Excuse me -
I really hope you are joking. Buy the program, that will get rid of the ad. Or just use a different program.Originally Posted by awhitney"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
You are asking about how to get rid of something that is there as a Reminder/Annoyer to get you to register the program. This would in effect be Warez (illegal software) and against forum rules. Therefore a warning was issued. I would suggest registering the program.
Sounds simple enough, excuse me for asking. That warning is not necessary though
hi awhitney..
Yeah, that logo IS a pain, and reason I gave it up... and went with DVIO,
which is freeware
But, if you have windows 98 and FAT32, you'll suffer the 4gig filesize limit.
If you have w2k or greater, and NTFS turned on, or formated system, you'll
have continuous capture (greater than 4gig)
Now, I use DVIO under windows 98, but that does not stop me. I mostly only
TV projects from my Satellite (DirecTV) So, when it commercials, I just
top and restart when it comes back, or I could wait till the second comm.
and stop.
I do not recall the D/L link for this app, cause Baldrick did away with his
old "tool page" where he had indivdual link, and associated descriptions
to each app, which I felt was a good feature. Anyways..
If you ask around or do a goggle search, you should be able to find it.
latest version I know of is DVIO v1.32 - - so, check it out if you
think it will work for your setup.
Have a good weekend all.
-vhelp -
that's funny... I went to the new Tools page, clicked on "Capture" and found a description for DVIO and a download link.I do not recall the D/L link for this app, cause Baldrick did away with his
https://www.videohelp.com/tools#Capture- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
@ housepig..
LOL.. it's there now. When last I saw, I couldn't find the "templates" for ie.
And, then I started looking for other things that I "used" to see, but didn't,
anymores. That was a few weeks ago.
I guess its ben fixed now
oh, and looking great too 8)
-vhelp -
yeah, it took a couple weeks to get all the tools shifted over to the new list... Baldrick is only human, after all...
- housepig
Housepig Records
out now:
Thanks for your help guys
I appreciate it. DVIO works great!
Does anybody know any other DV capturing programs that have a timer? -
Just might comment that I purchased Scenalyzer LIve (it was only $30...don't know if it's teh same now or not) because it works so well.
In my experience, it is MUCH LESS PRONE to dropping frames than other programs. Not that I've tested that many: Premier, MSoft Movie Maker; DVD WS; couple others I now don't remember what others. But, I can capture with 0 frame loss, and never do with anything else.
Also, you can work with the files, to some extent, while it is capturing. I like to capture into multiple files based on time stamps, and sort into directories by topic. It is a nice tool for working like that, and you can do it while it captures.
And, yes, you should purchase it to get rid of the ads.Thanks
Roger
How to author a god damn dvd with subtitles?!
By Redhotpengy in forum MacReplies: 7Last Post: 7th Jan 2012, 05:51 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 20:00 -
damn Subtitles can't be burned ?!
By insext in forum ffmpegX general discussionReplies: 19Last Post: 13th Dec 2008, 06:49 -
Dust particles on every damn Verbatim and TY Cake Box
By faramith in forum MediaReplies: 17Last Post: 20th Oct 2007, 16:10 -
Damn U DVD Studio Pro! Widescreen DVD Playback on 4:3 Monitors
By TRAK in forum Authoring (DVD)Replies: 2Last Post: 25th Sep 2007, 03:20
