I have converted many PAL SVCDs to PAL XVCDs with TMPEG and all have turned out fine, but TMPEG chokes on one file.
I load it up, have the settings set, hit start, it starts converting but slows down to a crawl at around 20 secs into the process. If I leave it alone, and come back in an hour, the converting time will change from around 3:47 to 79:30. If I try and hit stop, I get a "not responding" message from XP. Not only that, if I open up the task manager, the priority of TMPEG is usually Normal, but after the choke, it drops to Low.
I have converted other PAL SVCDs before and after this event and they all come out fine and in a timely fashion.
I have even run this MPG thru VCDGear mpg->mpg fix errors and it said it fixed 13 errors, but import back into TMPEG still the same choke.
The original seems to be fine, I burned the MPG as an SVCD and it plays fine (my dvd has trouble with PALs 576 resolution though and looks kinda jaggy, that's why I convert to VCD and play in my other player that can handle PAL resolutions but not SVCD) So I decided to copy the avesq1.MPG file from the disk and load that into TMPG, that comes up as unsupported.
I have the environmental settings set up as has been suggested before.
I'm running a 1.5GB P4 w/256MB RAM and I am at the end of my rope, has anyone else experienced this and have a solution?
I appreciate the help,
scottymac
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 16:20 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
HD Mpeg2 Stream - playback/edit issues. Even VLC chokes
By bengance in forum DVB / IPTVReplies: 29Last Post: 2nd Nov 2007, 11:05
