OR PUT SIMPLY HOW DO I SWITCH THE VIDEO OF A PRE AUTHORED DVD WITHOUT LOOSING SOUND OR MENUS ?
ok I know its ameture night
in plain language..my freind authored a dvd...great 5.1 sound but picture isnt great at least not as great as the quality of the one i have on vcd...so what i was trying to do is take my picture and put it to his sound a nd reburn to dvd
the dvd menu has ifo and bup files as well as the mpeg [actually that would be 3 mpegs.titled vts-01-1,vts-02-2 and vts-01-3]..i did what you said and demuxed one is picture the other ac3
just like the 3 chapters on the dvd theres 3 parts to the vcd...but from what ive seen they arent exactly slit at the same exact point..pretty close though...so i imaging i has a little editting to do?
iv e also used [s]vcd2dvdmpg and split the sound and image file out of the vcd...where i noticed it doesnt look too shabby but theres a empt y green field at the end instaed of the picture taking up the frame....uuuhhhh... any helpfull tips...and sorry to keep disturbing u
thanx again
Results 1 to 1 of 1
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
How doI keep original subtitles?
By anubisjazz in forum SubtitleReplies: 0Last Post: 10th Jan 2010, 01:13 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
How to make DVD using MPEG Video Wizard DVD?
By nightcat in forum User guidesReplies: 1Last Post: 6th Aug 2007, 13:52
