I have a VHS video that plays fine only the audio is laging a mili sec behined...its an old Sinatra video with lots of singing and its very rare....how can I re-edit / repair and burn to a DVD?...I have a DVD - Pioneer burner...key words for a search will do if u dont wana type ...tks for any feedback...![]()
the best card I have tried for vhs tape's is the ATI AIW the only problem is that some NTSC tape's do not display right. The only FIX i know of is to use a world wide vcr send the tape out as pal-m or pal-n then capture as pal-n or pal-n and ever thing should be fine you can get a ati all in wonder for $50.00 dollars at www.pricewatch.com new ati aiw cost around $500.00 or thenew card's are just better for video game's. If your not a games just get the $50.00 dollars one it still play all new games fine
I don't know what you are using to capture with. I use a Pinnacle DV500 and have no problem with audio and video sync. I have heard that
Scenalizer Live is a good capture program for analog and corrects sync problems. -
I have an Asus TV 880 c-card works fine...the VHS tape it's self has the audio problem ...when I play back in a VCR...How I recorded it like that God knows? but Im asking can I re-edit it to a DVD or back to my harddrive repaired with the audio in sync?...tks again for the feedback
If you have Premier or something like it you can sepparate the audio and video and then adjust as neccessary. Then compress, author, and burn.
like sdlehman said, if the vhs is out of sync, you can just move the audio until it syncs up.
if it is a progressive problem (it starts out of sync but then gets back in sync, or it gets worse out of sync as the program goes on) you may have to split the audio into segments, and align each segment with the corresponding video.
In that case, I would split the audio for each song as a seprate wav file, make sure they all line up, then cut some applause or crowd noise and paste it into a secondary audio track to cover any gaps.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
VHS player connected to PC - all captured footage out of sync!
By kingmustard123 in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2011, 16:23 -
Captured VHS movie and .srt subtitle not sync'd. Any way to fix?
By snafubaby in forum SubtitleReplies: 2Last Post: 17th Aug 2009, 02:52 -
VHS to DVD sync problems
By loa909 in forum Newbie / General discussionsReplies: 1Last Post: 1st Apr 2008, 15:01
