I have so far been unsuccessful in using SVCD2DVDMPG+ because the program hangs after resampling audio and enters into the 'multiplexing elementary streams' phase. Task Manager in Windows XP shows that the application is still running okay and I am led to assume that the program is doing its thing. But after waiting overnight and checking in the morning, no progress is made and no DVD files were created.
All current updates of the program have been installed via the auto update feature. The version of BeSweet is also the latest version.
I have now uninstalled the program and the .net framework and will try reinstalling it again.
Any comments would be appreciated.
AnonymousGuest
besure you used the right version of besweet v1.5b17 or v1.5b18 else it will not work. ( i used v1.5b18)
how long did you wait? Cause it could take some time to run.
yf -
AnonymousGuest
I have the same problem, but my program hangs durring the Multiplexing elementry streams. When using a bin it creates the mpg file, but not the VTS. Just got the new version of SVCD2DVDMPG+, but still no luck. Wondering if anyone could help? Thanks
Losslees Audio on DVD player without resampling
By ITISRAVI in forum AudioReplies: 7Last Post: 22nd Jun 2011, 23:28 -
Resampling for online streaming.
By John3 in forum AudioReplies: 5Last Post: 16th Mar 2011, 00:01 -
Resampling audio
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2009, 11:24 -
Resampling Audio
By Germanicus__ in forum AudioReplies: 18Last Post: 19th Jun 2009, 03:55 -
Audio Issues: Resampling, etc.
By tacman1123 in forum ProgrammingReplies: 3Last Post: 21st May 2008, 06:36
