I have this program and its lightning compared to TMPGEnc.
Unfortunately when you use AVI as the source is does not keep letterboxed video. It turns it to full screen and makes the aspect ratio wrong.
1) Is there anyway to sort this out??
2) Is there another program that users the Main Concept Encoder for encoding and gives you the option to "keep aspect ratio" like TMPGEnc does.
Cheers
Fozzee
If you have the stand-alone encoder, you can frameserve from Virtualdub, and Use Virtualdub to resize,crop, letterbox etc.
Typically, if you are going to encode to (e.g.) vcd, then use the resize filter in vdub to letterbox and resize to 352*288. Play with it and use the preview to make sure you have it right aspect-ratio wise.
Start the vdub frameserver, save a .vdr file and open it in the encoder. Should work fine. -
Hi
Are there any guides on this site how to frameserve with Virtual Dub??
I have never frameserved before and have no idea how to do it.
Fozzee -
here's a couple:
https://www.videohelp.com/forum/userguides/87270.php
https://www.videohelp.com/virtualdubframeserve.htm
You will need to use the virtualdub filters (video/filters/add). Null transform (cropping) if you want to trim anything off the sides, and resize (with letterbox option) before you start the frameserver.
Do a quick search and there are a number of posts dealing with examples - its pretty easy and intuitive once you've done it once.
Creative Media Format (.CMV) proof-of-concept encoder
By plexx in forum ProgrammingReplies: 8Last Post: 15th Jul 2011, 16:13 -
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
