  1. I have just built a new pc today exactly the same spec as I already have for converting movies.(AMD 2000+, 256 DDR 2700, 40gig hdd, Geforce gfx card, Win XP)
    Using the same codecs (Angelpotion, Nimo 7 Build 5, & Xvid) which work perfectly on my old pc but I have to decompress the avi/xvid to get sound through TMPGEnc
    Used Gspot & it says all codecs are installed but I`m stuck at whats going wrong
    Been on 6 hours trying to sort it but I`ve gave up & hoping one of you guy`s can help me out
    Any suggestions are GREATLY appreciated
  2. You have been extracting the audio as a WAV ?
    "Today is only yesterdays tomorrow"
  3. I`ve never had to extract anything in the past, just encoded it straight from the avi file
  4. Personally I find that I have to extract the audio as a WAV before encoding with TMPGEnc and with XVID I leave as is and encode.
    Woks every time for me.
  5. Got it sorted 8)
    Uninstalled everything then just put Nemo Codec Pack 5 (Build 7) on & set it to "ENCODER" in the installation, now it does the sound without having to rip the audio
