Hello everyone. Finally got a Card with TVIN and I'm not having all the fun I thought I would be.
Im using:
AMD 1.1ghz, 512 Mgs Ram, ATI Raedon 64 DDR
Followed ATI walkthrough.
10 Seconds into a capture same frame will repeat while sound goes on through. Also theres a slight space at the top edge of the capture showing new frames while the bottom majority of it still repeats same visual frames.
Any suggestions please.
Macrovision.
If you are using Win98 and PAL, you are stuffed. If you are trying to capture a macrovision-encoded source, then that is your problem. If your source is legitimate, I would take back the card and get an alternative.
I have tried for 2 months to get a Radeon AIW to capture from a number of legitimate sources, including all the hacks going and even a macrovision stripper, and still no joy. Despite being comparatively clunky, and not without it's foibles, at least my WinTV PCI Radio card works. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Does your MB use the VIA chipset? If so, then you may want to go to their website and download the updated MB drivers. This didn't fix it for me, but you may have better luck. According to ATI, the AIW's have a problem with some of the VIA chipsets.
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
