I have ATI MMC 7.9 and the largest resolution for mpeg-2 capture is 640x240. IS there anyway to capture in 720x480?
Results 1 to 11 of 11
I had MMC 7.6 and capture 720*480 and I upgrade to MMC8.1 and capture 720*480 may be MMC7.9 they forgot to put in 782*480 in MMC 7.5 the mess it up they had a DVD setting but the audio was 44.1 not 48K and you could not even make a DVD even thow they but the DVD template in there. Or you might have a bad install. If I was you upgrade to MMC 8.1 or MMC 8.5
this may sound dumb, but where can I get MMC 8,1 or 8.5? ATI's site only has 7.9 and I can't find it ona search.
No. Only to use the DVD Player. Ignore the "own the CD" warning, and download and install. You'll get a nag message that say "cannot install DVD Player". Just hit okay, and move on. I have PowerDVD and WinDVD, so I couldn't care less.Originally Posted by andkiichI'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
Go here:
http://mirror.ati.com/support/driver.html
Select Multimedia Center, your operating system and then the product you have and it will point you to a download for MMC 8.5. I have to AIW Radeon 8500 so the link it gave me was:
http://www2.ati.com/drivers/mmc-8-5-0-0.exedj matty b
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
