alright, it's coaster central over this way and i need to know what media works best.out of typical +R 25packs of tdk 4x, memorex 4x, and fuji 2.4x... more than half turn out bad ranging from end of disc errors to totally locking up my laptop to only reading back from the burner drive itself and not the internal dvd-rom.
it should also be noted that i'm merely backing up high data rate mpeg2's (higher than max DVD spec) extracted from a DVR. most files are around 2.5 gigs, yet some are 4.0 gig. while success is rather "hit or miss" with both, naturally the larger 4 gig sizes give the most problems.
i'm using the latest version of nero with the UDF 1.02 DVD setting and both the burner and the external HD currently storing the mpegs are connected via the faster USB 2.0 interface...?![]()
