I'm a little confused....I'm trying to follow the DVD Shrink guide and this is what it says :
[quote](4.) Select the lowest level nearest the DVDR/W 4456 MB size limit (5.). Lower level means less compression which means less video quality degration. Try use a level lower then 7-8(if it wont fit even if you select level 8-10 then I would recommend to split to two discs with another tool, but you can always try and burn on DVDRW to see how it looks like).[/quote
The levels are 1-10. 2 questions: Is the lowest level considered 1 or 10. And is this saying try to get as close to the DVDR MB limit (which is 4456 per exwithout going over. Help would be greatly apprecitated
You are probably better off looking at the green/red bar to determine which is the lowest you can go (lowest/highest IS a confusing statement).
1 - least amount of compression (best quality)
10 - most amount of compression (worst quality)
when you load your dvd in and it reads it, the bar will show green (and more than likely red). Remove the audio and subtitle/close captioning items that you do not want when you reauthor the dvd. After that, try to knock out the beginning and credits for the movie, so you JUST have the movie, If the bar is still red, begin going down the compression list until the bar is in the green.
Depending upon the media, you might want to make sure you leave at least 100 mb open as some dvd-R's have issues on the outer edge. -
Just to add a little to that excellent analysis, DVDShrink also "errs" on the side of conservatism (it's also adjustable if you want). I find that often I can successfully create DVDs that are a little in the red, because the compression is underestimated.
And make sure you're using version 2.3, which does a far better job at higher levels of compression than any previous version."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
