Results 1 to 10 of 10
  1. I just found this great DVD ripping tool, Chopper XP. It allows extraction of a portion of a DVD with a video display.
    I used it for a few DVDs and it worked well with them.
    You can find it at http://www.digital-miner.com
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    correct me if I'm wrong, but Chopper is not a ripping tool, but a vob editing tool (unless they've added ripping to a new version)?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Originally Posted by housepig
    The new version can also decrypt CSS encrypted DVDs and so it is a ripper.
  4. Is there any guide for Chopper XP?-B
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    fair enough... I'd noticed there was a new version floating around, but I haven't run into any need to cut a vob lately, so I hadn't checked it.
    - housepig
    Housepig Records
    out now:
  6. Is there any way you can see the live video? As I tried video just freeze in the begining.-B
  7. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Great program..
    CUTS VOB's short with just mark in, mark out..
    BUT THEN YOU MUST SAVE AS..new file name...
    It doesn't JOIN.. but then its free and its CHOPPER XP
    I'm using it under 2000 ..I see good video preview of what i wanna choose from as soon as I open a VOB (I've only tried with already decrypted files on the harddrive..unless you're outta disc space you don't want to edit with footage coming from OPTICAL DISC directly as its slow)
  8. dcsos,
    Do you have any problem in begining to see video and choose the part you want? When I click on play, it play the begining video and then freeze. I can still hear audio. There website does not have information.-B
  9. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Seeing your post, I installed CHOPPER XP
    on 2 other windows 2000 machines.
    All 3 installed CHOPPERS
    are able to open a de-encrypted VOB and play the full content VIDEO and AUDIO in the program window.
    When I hit stop the clip goes back to the top..when i hit pause. it stays open to the frame I want to mark in (or out at)
    No problem..want me to try WINXP?
  10. Thanks for trying it out. I tried on XP and you are right it is working. It looks like something is wrong my 2000 machine. Any Idea what it could be? -B
