I'm converting my AVI files (captured via G400-RR MJPEG 740x480 30fps NTSC) to MPEG-2 files for archival until I get a DVD writer. I need to know if I should compress to 720x480 or 704x480. I tried the 720x480, but when I play the files using a software DVD player, there's a black strip (I assume 16 pixels wide) down the left side. Will compressing to 704x480 solve this ? Thanks for your help.
The reason why does 'black bars' were added after encoding was to 'Maintain Aspect Ratio' in TMPGEnc. You can encode to 720x480 *and* get Full Screen results by choosing Full Screen... *without the Aspect Ratio* in TMPGEnc. Try that. =)
Do you mean that I should use the "Fit to Frame" setting ? According to the rollover help, this will resize the image from 704x480 --> 720x480, which will make it just slightly wider.
Given the way that I currently have the files converted (as 704x480 aspect ratio), when I play them on an actual DVD, will it expand them to full screen automatically ?
-geoff
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 15:03 -
Combining and converting AVI (MJPEG) files
By vikasa in forum Video ConversionReplies: 0Last Post: 21st Jun 2010, 12:47 -
which muxer handles NTSC 704x480 2.21:1AR 29.97fps mpeg2
By halsboss in forum Video ConversionReplies: 12Last Post: 3rd Mar 2009, 20:39 -
Converting or Muxing audio files (mp3 etc.) into MPEG2 TS without any video
By kary.sharma in forum Video ConversionReplies: 1Last Post: 5th Dec 2008, 08:07 -
Best App for Converting MPEG2 files to WMV/WMA 5.1
By JBredensteiner in forum Video ConversionReplies: 13Last Post: 7th Oct 2007, 14:58
