Hello guys ive got a big problem with adobe premiere. When i render my video adobe premiere hangs after about 45 minutes of rendering, but not at the same frame. I use divx 4 and tried also 5 but i didnt help me. Anyone has / had this problem too? Or can help me?
What version of Premiere?
In 6.5 using the MainConcept encoder there is a problem that can be fixed by editing the Premiere .INI file -- this would cause a hangup or stop of the rendering after a short period of time. It *might* affect other codecs, I don't know. I can't say about earlier versions.
For more details visit Adobe's superb forum help for Premiere and other products. You'll get your answer in a few minutes."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
A little more information is needed.
What Operating System?
I know that versions before 6.5 have troubles in WinXP. I constantly had locking or hang on opening with v5, v6 is better, but v6.5 seems stable.
Does it hang on a specific clip? could it be a problem reading the source?
These are but a few of the questions that could help those of us here help you.--
Will -
Im currently using Windows XP and Adobe Premiere 6.0. I dont know if it hangs on other clips too, because im only editing one movie at the moment, but my input files are ok i tried to edit them with other tools (pinnacle and moviexone).
Are you using the MainConcept encoder that comes with Premiere 6.5? And are you capturing DV video?
If so, make sure you first upgrade to the latest version (1.3 -- there is a link on both the Adobe as well as MainConcept sites). Then you need to follow this procedure:
http://www.adobe.com/support/techdocs/2dffa.htm
Note that if this *isn't* your problem you ought to visit the Adobe support forums. They are free, fast and helpful, and even searching the knowledgebase can often solve your problem."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
if you have both 6.0 and 6.5 hanging on you, then you may want to contact Adobe tech support or check out their forums.... One thing I like about Adobe (my wife uses their software in her Graphic Design job) is that she is able to get through any problem that she has encountered with their software by either of those two methods.....
Besides, they are the ones who programmed the stuff, so they would know tons more about it than 99% of the people here... (not a knock on anyone because there are some very experienced users here)
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
My 2 problems with Adobe Premiere
By IT learner in forum EditingReplies: 2Last Post: 16th Sep 2011, 08:46 -
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 03:14 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
MiniDV to Adobe Premiere to ?
By p3ngu!n in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 16th Sep 2008, 08:10
