im stil havin problems gettin a dvd to work in my dvd player. ive tried my mates dvd in myne and it works fine and it also works in my ps2, but then i try myne and it dnt work in either. i have used nero to check the medium info and my mates one is UPC/EAN CODE: UDF/ISO9660 (MODE1) Where as myne is just the same !! ive checked how he has done his and they are all in IFO,VOB and BUP form the same as myne. But yet again it still dont work. Could it be the disc i am using or could it be sumthing else?
Hi, it could be the media you are using.
What method are you using to burn.
I prefer nero (latest version) using the dvd video template.
So far I have a 100% compatability record with stand-a-lones.
dlb. -
Hey, i am using datawrite 4x dvd-r 4.7gb disks and i am also using the latest nero to burn them. But i do not know wheter to use the DVD ROM (UDF) OR THE DVD-ROM(UDF/ISO) !!
Use the following settings in Nero;
1)DVD-ROM(UDF/ISO)
2)No Multisession
3)ISO settings ISO level 1,ISO 9660 (Joliet is disabled)
All ISO restrictions Disabled(Allow path depths etc OFF)
Also make sure UDF1.02 is checked as the physical partition.
Anyway, weren't you going to use Ulead DVD Movie Factory to author your DVD? It would have burned straight to disc without fail. -
Is your VIDEO_TS directory in capitol letters? Some DVD players require capitol letters. You should use capitol letters to assure compatability.
yes laddydaddy i am using ulead to authour it etc but it still wouldnt work on my dvd, yet i tryed a mates dvd and hes done it the same way as me and his works on my dvd and my ps2, so i am assuming that it is maybe the disk im using !! its maybe not that good
