HI!
when i ripp the movie with dvd-decrypter i use "file mode" and select "main movie files" only, i get one .IFO file and a couple of .VOB files in my target folder .Shouldnt there be more files , .BUP etc. or do i have to choose more files manuallyexept the "main movie files" . After doing this ripp the movie cant be opened with dvd shrink,it say something like"file doesnt exist" THANKS FOR HELPING!!!!!!!!!
You are better to rip all the files and then choose todo a full disk copy or a re-author in dvd shrink.
dlb. -
when i used dvd2one after dcrypting like i described, i got more files and it also worked open it with dvd shrink!!
danne,
like dlb said, use dvd decrypter to rip the whole of your dvd in file mode and the open up dvdshrink if you want to just have the movie only then go into re-author select movie only, drag and drop, and burn.
if you need more info clicl the below link
http://www.doom9.org/index.html?/mpg/dvdshrink2-main.htm -
Ok , but then i dont have to use dvd decrypter ,dvd shrink has built in decrypter . I thought that dvd decrypter was better or ??I dont like that you cant set the exact output in dvd shrink so iŽd rather use dvd2one.
By the way .... hoe do you know wich is the main movie file if you have 2 tracks at exct the same size and length?????????
danne
I would agree DVD Shrink's inability to control output size makes DVD2ONE preferable. Trust DVD Decrypter,it will select the "main" movie.
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 15:48 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 27th Jan 2008, 00:35 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 23:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 17:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 09:12
