I have an hitachi camcorder (8mm) and I'm trying to hook it up to my Sapphire Radeon 9000 PRO. My camcorder has 2 composite outputs - 1 for video and 1 for audio (mono). The input on the radeon had 1 video and 2 audio (stereo left and right). I thought I could simply hook it by connecting video to video and audio (mono) to audio (use just 1 stereo input/left or right). The picture comes up fine but I cannot get the sound to work (on my pc).
I hear there is a 1 phono to 2 phono cable availible but I cannot find it anywhere....
Can anyone help?
Do you have you capture card connected to the line in of your sound card. These cards do not capture the audio they rely on the sound card to do that.
Now I look pretty stupid dont I. I'll hook up the sound to my soundcard and see if it helps.
Problem capturing mini dv audio w/ camcorder other than one used to record
By Nuzy in forum Capturing and VCRReplies: 18Last Post: 22nd Feb 2010, 05:35 -
Help with old 8mm camcorder tapes
By AmandaBMidlands in forum Portable VideoReplies: 2Last Post: 11th Nov 2008, 08:43 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 18:51 -
What is the best camcorder for 8mm to dvd.
By krlorenz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2007, 13:58 -
Problem with old 8mm camcorder
By neilf1234 in forum Newbie / General discussionsReplies: 15Last Post: 26th Jul 2007, 08:04
