Hi everyone,
I'e decided to open a new topic to try to solve a problem I encounter frequently using Dvd2dvdr.
See https://www.videohelp.com/forum/viewtopic.php?t=164406
As I've found no solution, I've decided to try differently.
So, my question is :
Does someone know a guide or can describe the Post-CCE process in Dvd2dvdr ?
I mean, after CCE encoding is finished, Ifoedit opens the "Dvd Author / Multiplex" box.
The M2v stream file, the audio Stream(s) file(s) the Subpicture(s) file(s) and the Celltime.txt are filled and that's where it stops.
Does someone know how to do this in Ifoedit :
Copying Subtitlecolors
Adding PreCommands
Setting Audio to Preset
Setting Subtitle to Preset
Setting Provider-ID
Updating Vts Sectors
Thanks... a lot.
Whats the source you are working with in DVD2DVDR, PAL or NTSC? Answer this and i will get back to you.
Also in the mean time please check out my site. Link in the signature. On my site on the left hand side there are some links to guides and helpfull information. If this doesn't help you in anyway. Please reply.
or you can get the info straight from there.
http://users.pandora.be/DVD2DVD-R/UK-DVD2DVD-R.htmhttp://dvd.coldpie.com - where you can download versions of DVD2DVDR. -
Hi Wayned,
Thanks a lot for your answer.
I'm doing Z2 PAL Dvds.
I'm using a PIII 950 Mhz, HD100 Gb, Pioneer 106D, Win2k, NTFS.
I've done some Dvd5 with Dvddecrypter, tried CloneDvd, Dvd2one, IC and DvdShrink (what a beautifull piece of coding !) and never had any problem.
The reason I'm trying Dvd2dvdr is the quality of CCE...AMAZING !
Anyway, a nice guide you've got there, exactly what I was looking for.
I've burned a movie on a Dvd-rw to test it and it plays perfectly on my stand-alone Dvd Player.
So, it seems i've found a way to handle this.
But I still don't understand why Dvd2dvdr doesn't go till the end of it's process.
And I'm using the latest version, 1.4.9a.
...pandora.be, if you're from Belgium, thanks a lot neighbour.
Patrak -
shot in the dark do u use Norton anti virus.
Not Norton, Trend Officescan anti-virus.
What do you have in mind ?
I also have Pgp Desktop Tools, I thought it could be the problem.
I "logged on" using another Win2k Profile without Pgp but the problem occured again.
Thanks anyway -
sorry for the late reply, But norton anti virus does a little thing called script blocking. This used to be a common problem in the earlier versions, that DVD2DVDR would not finish all the way through the process.
I haven't used Trend Officescan anti-virus, so i can't comment on it. But i recommend either AVG or PC Cillin, Virus scanners.
Also before running DVD2DVDR process make sure you have turned of your screen saver and power settings, and if your going to bed or overwise just turn ur monitor off. Also any other programs in the background should be closed down. The less you have running the faster and more reliable DVD2DVDR will become.
What you could do is shut as many processes down as possible using Task manager, and see if it is a peice of software causing it to halt half way through the process.
cya good luckhttp://dvd.coldpie.com - where you can download versions of DVD2DVDR. -
Well Wayned, seems you've found something.
I've made 2 movies turning off my anti-virus...it worked perfectly !
The Pc I'm using is at my office with a Corporate Anti-virus, I can't change it, but fortunately I can turn it off when needed.
I'll try some more movies to be sure.
I admit I should never have thought of this as being the cause of my problems.
So, thanks again a lot for your help.
Bye
Patrak -
So, last thread to close this topic.
I've made a few more movies and everything is just perfect !
So, as a conclusion and for those who will search in those forums :
TURN OFF YOU ANTI-VIRUS WHILE USING DVD2DVDR !
Bye
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
Process description.....
By zok4me2000 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2009, 11:25 -
New Computer > Need New Process
By msdker in forum Newbie / General discussionsReplies: 2Last Post: 14th Mar 2009, 17:18 -
how to keep the HD in my conversion process?
By masadar in forum Newbie / General discussionsReplies: 9Last Post: 21st Dec 2008, 12:41 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 15:45
